  3. How to change the default via padstack
  • Views 20552
CarloL
CarloL over 15 years ago
I have to change the padstack used to place a via during the autoroute process.
I have defined a new BBVia from menu setup->BB Via Definitions -> Define BB Via, but  it doesn't work. The used padstack is, always, the VIA pad.
Carlo
  • redwire
    redwire over 15 years ago
     And make sure that your start and end layers match that of the blind via so that Allegro will offer you that choice as well while routing.
  • redwire
