  3. Adding of board height
  • Views 13369
C Shiva
C Shiva over 15 years ago
 Hi all,
  Is it possible to add board height means thickness in board outline? We can add component height in placebound. One of our customer asking to add board thickness in IDF file. Any way?
Shiva.
  • C Shiva
     While exporting IDF file, default height 1.6mm will be there. I need to change it as 1.88mm. Any idea?
  • steve
    steve over 15 years ago
    Shiva
    The Board Thickness is taken from the cross section thickness. Set this up accurately so the total equals your board thickness. This is also true for the 3D view in 16.3
  • C Shiva
     Thanks Steve for your quick reply. I can't view the board as 3D since our's is 16.01 version.
