  3. Replacing Components in OrCad Capture CIS
  • Subscribers 167
  • Views 20540
Goblin60
Goblin60 over 15 years ago
All,
I have an old design that I have to bring up to spec. I have 240 resistors of the same value/size that I would like to replace at the same time with an updated part. What's the magic formula?
  • Goblin60
     Allow me to modify the question. I figured out how to do a group replace so the new question is how does one automatically rotate the part to the correct orientation? For example, my part had originally been placed horizontally but the part in the library was built vertically. Consequently, when I replaced the components, they placed 90 degrees off. Is there a setting that will allow me automatically rotate?
  • mdub
    mdub over 15 years ago
    I'm sorry i cannot help you on your rotation question, but can you tell me how to do a group replace? thanx
  • Lost
    Lost over 15 years ago
    Before placing go to Setup-->Design parameters ->Design -> Symbol -> Angle
     Set angle to rotation needed.
  • Goblin60
    Why am I getting this?
    Ron Scott CID+
    Neuromodulation Division
    St. Jude Medical
    6901 Preston Road
    Plano, TX 75024 USA
    Tel 972 526 4616
    Fax 972 309 8150
    Ronald.Scott@sjmneuro.com
    www.sjmneuro.com
  • Ejlersen
    Ejlersen over 15 years ago
    Hi Ron
    The key to replace cache in Capture CIS is that the resistor in your library needs to have the same rotation as the original part from your design.
    You can drag a copy of the design resistor from the design cache into your library and then make the changes you want, save the library and do a replace cache.
    Best regards
    Ole
