  3. issue with allegro
  • Views 14650
issue with allegro
lzping0810
lzping0810 over 15 years ago
i have a problem with my allegro pcb editor 15.7.When i want to import the netlist into allegro  .an error message appears like "program has encountered a problem and must exit. The database will be saves (if applicable). obtain the latest software update from cadence and if problem persists contact cadence customer support". thanks..
  • SandyM
    SandyM over 15 years ago
    The first thing I always do when I start getting messages like that is to run DBdoctor against the board. I have found that more often than not it takes care of the problem. Worth a try at least.
    Sandy
