  3. error name too long
  • Views 22338
error name too long
dumarjo
dumarjo over 15 years ago
 I have an error that I could not find a solution. Here what I got when I try to transfer design to pcb editor
ERROR(SPMHNI-164): Problems with device 'HEADER 15X2_1_HDRV30W64P254_2X1'. JEDEC_TYPE property 'HDRV30W64P254_2X15_3810X500X800P' is illegal: 'Package name is too long.'.
 When I save the  HDRV30W64P254_2X15_3810X500X800P.dra file with Allegro, I got this error:
 E- (SPMHSY-31): 'O:/Allegro/pcb_lib/symbols/HDRV/HDRV30W64P254_2X15_3810X500X800P.dra', name too long
I thing the path name is not really long, but I wonder if I can do something to get this error solve ?
I'm using Allegro 16.2Performance option.
regards
Jonathan
  • djhutchi
    djhutchi over 15 years ago
    Try adding the following entries to your %home%\pcbenv\env file:
    set allegro_long_package_name
    set allegro_long_name_size = 64
  • KEN13
    KEN13 over 15 years ago
    Jonathan,
         Open your Design Parameter Editor and select the Design tab.  In the first section you can change your Long Name Size.  I have mine set to 255.
    Ken
  • dumarjo
    KEN13 said:
    Jonathan,
    Ken
    This have corrected the Error in Allegro. But I have the error on Capture again. I have also  done what djhutchi tell me. Same error.
     I don't know what to do now !
    Jonathan
