  3. For 0.5mm Pitch QFN package the fuducial pad is required...
  • Views 13612
For 0.5mm Pitch QFN package the fuducial pad is required or not required?
Raam
Raam over 15 years ago
For 0.5mm Pitch QFN, local fuducials required or not required? IF yes, please tell me the standard fiducial pad location for the QFN component.
    archive over 15 years ago
    Yes. It depends on the assembly house.
    As per my understanding, you don't need to add local fiducials to any of the chips unless otherwise you are pasting the PCB using a local stencil. Global fiducials are enough otherwise.
    I normally use 3 global fiducials on geometric extends of the board.
    The size can be:
    Pad: 40 mils
    Soldermask: 80 mils
    Solder paste: 40 mils
    (Rule: If pad radius is R, Mask radius should be 2R)
    If you want to add local fiducials for the ICs you can use this values itself. Place this pad in the diagonal corners of the IC. Use an 80 mil diameter route and via keepout for the fiducials on ETCH/TOP layer.
    Hope this helps...
    Babu
    The size can be:
    Pad: 40 mils
    Soldermask: 80 mils
    Hope this helps...
    Babu
