  3. CIS Database "Value" not visible
  • Subscribers 166
  • Views 3104
mdub
mdub over 15 years ago
I've recently updated to 16.3. I have also recently created a new CIS database and now it seems that the "VALUE" from the database is not being placed on the schematic with the part by default. I can go into each instance of the part and correct this but this is not very efficient. How can I get "show VALUE" back by default?
  • eephillip
    eephillip over 15 years ago
     That is done in design entry CIS, you need to modify your .DBC file. Open design entry go to options>CIS Configuration. Then hit setup. Cycle through your tables and make sure the visibility colum is checked for the property you want shown by default in your schematic.
  • mdub
    Thank you for the response. I performed the actions you suggested. Now I am able to see the value on page; HOWEVER, the part cannot be seen. It appears its somewhere "off page". Any idea how to correct this?
  • eephillip
     Yeah that is a bug i've seen before, use the arrow keys when you double click the part to place it, the part should snap in or eventually work its way back in.
  • mdub
    not really working for me. i press the arrow, see the part, but when i click to place it dissapears again.
  • alexa1973
    alexa1973 over 15 years ago
     Open your schematic page. Go to Place -> Part. Click on Add Library. Select all your schematic libraries (*.OLB) and press on open. Restart Capture. Should help.
