  3. Variable changes with time
  • Views 15025
jun1119
jun1119 over 15 years ago
Hi
I would like to simulate a circuit with variable capacitor where its value will change with tme instead of giving several traces for different values as in parametric sweep. How can it be done?
[URL=http://img214.imageshack.us/i/91061656.jpg/][IMG]img214.imageshack.us/.../URL]
The desired input is:
[URL=http://img209.imageshack.us/i/10878748.jpg/][IMG]img209.imageshack.us/.../URL]
with the output:
[URL=http://img220.imageshack.us/i/30543651.jpg/][IMG]img220.imageshack.us/.../URL]
Thank you and Best Regards
  • jun1119
    Well, I mean on the VC_CAP block, there is a CAP = 1U where 1U is a value that you can change. Also, when you double click the word VC_CAP, you can key in some values too. Double click it into its property and you will see there is a column for "value" which can be changed by clicking "VC_CAP" and another column labelled "CAP" with the value 1U. What are their relationship? Shall I just set the capacitance I want in the "value" column? For the voltage, I will just have to connect a vsin at the left terminals right?
    Thank you
  • jun1119
    Thank you
