  3. design path error???
  • Views 13954
kabalee
kabalee over 15 years ago
 Hi everyone,
if i go to  setup-->user preference-->design path and import my library  in padpath and psm path and i click apply button error will occur i could not find what is error please suggest any body to help.
NOTE:when i working in local log in means error will not appear, if i work in server log in means error is appear
  • kabalee
     hi oldmoudly ,
    thanks for your quick reply.i check both case of login,same path is assign for in env file. what will i do to import library path
  • kabalee
     hi oldmoudly ,
