  3. resizing a "circular" shape
  • Views 2108
pcblayoutguy
pcblayoutguy over 15 years ago
Is it possible to resize a circular Shape (such as the way you can resize a rectangular shape) created by using Shape>Circular command? This would be for example a circular shape created on the Package Geometry/Dfa_Bound_Top layer during creation of a new package symbol.
  • redwire
    redwire over 15 years ago
     Try Edit->Zcopy and just put the copy on the same layer.  Use "expand" or "contract" as required.  Then delete the older shape...
  • eephillip
    eephillip over 15 years ago
     I took a class on these tools from someone who had been working with cadence products way back when a Gerber flash was created using a wheel and a light source. The message was if it takes you longer than a couple minutes to do something chances are you’re better off deleting it and starting over.
    This feels like one of those cases.
  • redwire
     Hmmm...good comment from a newbie poster.  Takes about 20 seconds.
