  3. Placed Component Report Sorting
  • Subscribers 163
  • Views 14728
Toolman
Toolman over 15 years ago
 When generating a customized Placed Comonent report is there a command symilar to the REFDES_SORT that will separates the components into a Top and bottom placement (SYM_MIRROR all top (NO) then all bottom (YES)?
Using the csv file and Excel sort almost works but does not sort incrimanetally only alpha numerically.
  • oldmouldy
    oldmouldy over 15 years ago
    Not quite, but you can get "Top Placed Components" and "Bottom Placed Components" in two reports by making a copy of your "placed report" and adding the following as the last statement in the report file BEFORE the END statement:
    for TOP add SYM_MIRROR=NO and for BOTTOM add SYM_MIRROR=YES
    You can then "glue" the two reports together in Excel, if that is your requirement.
