  3. hiding selected etch
  • Views 13071
stellar
stellar over 15 years ago
Is there a way to turn off etch selectively? I.E. you want to see the etch on the top associated with a particular net but hide all the rest.
  • steve
    steve over 15 years ago
    Yes - Use the shadow mode found under the color visibility menu - display, turn it on, then set the brightness level to dim (maybe 10%), then use highlight or assign color and pick then net you want to see. The remainder will be "greyed out" or invisible depending on the brightness level you have set.
