  3. Autorouter setup
  • Subscribers 163
  • Views 13190
Autorouter setup
tltoth
tltoth over 15 years ago
Hi
I've set up a min and max line width in the Constraint manager.
Under which circumstances  will the router use the maximum line width during routing process?
thanks
  • redwire
    redwire over 15 years ago
     It never does.  Will always go to minimum.  Line spreading algorithm will allow more room. If you need a wider line, set its min line width to what you need. Max prevents someone from going too wide (say for an RF signal)
  • tltoth
     thank you for making it clear
