  3. signal net vs power net
  • Subscribers 163
  • Views 15863
tltoth
tltoth over 15 years ago
Hi
How is it possible to define a net to be power net without assigning it to a power plane.
I've a double sided board and the router complains for to many pins on GND nets.
The router considers GND as signal net.
thanks
  • redwire
    redwire over 15 years ago
     Did you assign it a voltage?
  • tltoth
     No. But when I defined, it gave the same message.
    # <<WARNING:>> Net GND1 is defined as a signal net and contains 120 pins.
    # This is more pins than most signal nets contain.
    # Please verify whether net GND1 should be a signal net or a power net.
    # Note that a signal net will be routed as starburst or daisy chain.
    # <<WARNING:>> Net GND3 is defined as a signal net and contains 114 pins.
    # Please verify whether net GND3 should be a signal net or a power net.
    # <<WARNING:>> Net VCC3 is defined as a signal net and contains 101 pins.
    # Please verify whether net VCC3 should be a signal net or a power net.
