  3. to convert max file to brd file in allegro 15.2ver
  • Subscribers 163
  • Views 14505
Anonymous
Anonymous over 15 years ago
Hi All
How to convert max file to brd file in allegro 15.2ver
....\tools\pcb\bin\l2a.exe....
I tried this path but there is no exe of this name.
am working with ALLEGRO 15.2 ver. I tried the second also> there is no option such as
PCB Editor Utilities-> Orcad layout translator in 15.2....
Can u help me by giving out anymore inputs to convert max to brd in ver 15.2
ARFAJ
  • KeithP
    KeithP over 15 years ago
    You are correct the l2a utility does not appear in my sortware tree until 15.7.
    You can open a 15.7 database with 15.2 so with the correct versions of software there is a workaround
     KP
  • Anonymous
     Thanks keith.
    No other solution is possible without updating version?
    ARFAJ
  • KeithP
     Back in the days of v14 the translator came separately from Cadence and it was called toallegro.exe. I have tried this on v15.2 and no joy, it does not work, unsure why.
    v15.7 was the first version that I can find that had the translator built-in.
    Does anyone have the Cadence supplied version for v15?
    Alternatively, contact your cadence applications engineer who may have a copy for your specific release.
