  3. move non-grid placement&via to grid
  • Views 1707
Jeffyjames
Jeffyjames over 15 years ago
hi all,
can anyone help me out to move non-grid placement and via(already done placement and fan-out) to move to grid.Is there any option to carry out this movement or any skill?.
it is difficult to move component or via one by one after picking up and give snap to grid. please give me a solution
  • steve
    steve over 15 years ago
    If you know how far you are off grid then use Edit - Move, then RMB Temp group (make sure your find filter is set) the window select your items, RMB Done the pick an origin and the at the command line type ix the distance you need to move it back on grid (i.e. 0.5 0.5) hit return and the group will move.
  • Jeffyjames
    Hi steve, Thanks a lot for your immediate reply. Problem here is I was doing placement & via with 1 mils or .1mils. I don’t know how far I need to move exactly. All these components and vias will be in different offset. So not able to find out exact offset to move. Please suggest.
