  3. How to put board data in a *.osm file
  • Views 14328
purikku22
purikku22 over 15 years ago
i have created a board data, and i have a separate drawing frame (*.osm).
I need to put the brd data in the osm file.
any help? this will be the first time im doing this.
thanks.
  • steve
    steve over 15 years ago
    Since the drawing frame is a format symbol (osm) you place this into the board file so you need to do this the other way round.... If you want to create a mechanical symbol which contains the board data and the drawing format symbol then you could use sub-drawings to get the data together.
  • purikku22
     Thanks steve. i already figured it how. ciao
