  3. how to replace or rename the off page connectors
  • Views 23185
mfshakir
mfshakir over 15 years ago
I have off page connectors on different sheets and i want to replace some of those with new names ,how can i replace all at once
  • oldmouldy
    oldmouldy over 15 years ago
    Assuming that you are using the Capture front-end, select the DSN, Edit>Browse>Off-Page Connectors, select the off-page connectors to rename, use left-click shift+left-click for a range control+left-click to select items, Edit>Properties, change the NAME property of the selected Connectors, OK. Select some more, if required.
  • mfshakir
    Thanks for your reply, i think i am unable to explin clearly what i want to do, basicly for off page connector we used in different pages , i want when i change off page connector for any net it other part also replace same time,i just want to avoide it manually on different sheets
  • oscar migs
    oscar migs over 15 years ago
     EMA has a useful script w/ a tutorial to replace net names.
     Not sure if you need an account, but here is the link:  http://support.ema-eda.com/download/LabFiles/Capture_Script_Files/replace_net_name.zip
    Best,
    -oscar
  • tenny
    tenny over 13 years ago
     hi , i tried the script it's get work.   is  there any way to change the "off page connector "  net name same with the net alias, when add a off page connector to a net assigned net alias ? thanks .      i offen met the case there have a lot a of net need connecte to different pages and it's not bus.
  • tianli
    tianli over 12 years ago
    hi tenny
    i have read your post "/forums/p/17594/1248024.aspx"
    have you find out how to replace the "off page connector name  " with the connected "net alias name".
    i modifyed many net alias name in batch with property editor .but the off-page connector name can not be modified .
    the most stupid method is manually modify one by one of the off page connector name ,corresponding to the net alias name.
    thanks
    kind regards!
    tianli@sa.buaa.edu.cn
