  3. How hide shapes only?
  • Views 8199
kv193
kv193 over 15 years ago
Hi all. I use OrCAD PCB Editor. I have done the pcb with gnd filled shapes on every layer. Later I needed to add some components to design. But pcb with filled shapes on every layer is difficult viewing. Can I hide filled shapes (class ETCH) only, at the same time etch track left visibility?
  • oldmouldy
    oldmouldy over 15 years ago
    If you have OpenGL enabled, set the shapes to Transparent, Display>Color / Visibility, Display folder, set the Shapes Transparency.
  • oldmouldy
