  3. Differential Pair Check
  • Subscribers 163
  • Views 12585
purikku22
purikku22 over 14 years ago
 Hi, I have a board wherein the differential pair gap were change from 0.165 to 0.140mm. I used slide tcommand to correct the new gap. Is there a easy way to check all differential pair gap. I am using show measure (manually) to verify if the gap is 0.140mm (XNET is applied to these signals). Just wondering if there is a way... any help or suggestions??? thanks in advance
