  3. Orcad 16.3 installation and uninstallation with SCCM
  • Views 14999
KasperB
KasperB over 14 years ago
Hi.
Not sure i've made this post in the correct forum. feel free to move it to where it belongs.
I've spend the last couple of days trying to package Orcad 16.3 for SCCM, the Installation now works silent after following the provided guide in pcbInstall.pdf, running the setup.exe with !quite=quiet=<path_to_your silentinstall-SPB.ini
file>  and aftewards installing the latest hotfix.
There is no documentation for unattended uninstallation of the product in the pdf. - Is there an officially documented method of doing unattended uninstallation?
Since it's an Installshield installer, I've tried recording an uninstall.iss answerfile with no luck (seems the first dialog is not suppressable), and experimented with various parameters.
Only solution i've found is making an autoit script, but this still allows the user potentially messing up the uninstallation, and is not really satisfactory.
Any ideas?
EDIT: Hmm, no line shifts?
EDIT2: Now with line shifts :)
