  3. can someone enlighten me this terms
  • Subscribers 162
  • Views 15307
purikku22
purikku22 over 15 years ago
In Padstack designer, there are fields for paste mask and film mask.
In our company, paste mask is equal to metal mask.
Film mask is used for what aspect in design?
Thank you.
Just wondering! :)
Thanks in advance
  • oldmouldy
    oldmouldy over 15 years ago
    Film Mask is potentially obsolete, it originated from an old method for defining embedded components. You can use / abuse it as a user defined mask but the Solder and Paste masks are the required parameters.
  • Mstrghettorigg
    Mstrghettorigg over 15 years ago
    We use the film mask as a layer to create the silk cut layer. So for example, we make it 0.3mm larger than the pads so when we do CAM check we can make sure there are no silk within 0.3mm of open pad.
  • purikku22
     thanks for the reply! now i understand,
    @mstrg....that is a great insight. thanks:d
