  3. make a different net constraint inside constraint regio...
  • Views 15042
make a different net constraint inside constraint region
andri26
andri26 over 15 years ago
Hello,  I need some help in cadence. actually i just learning cadence allegro PCB editor now.
I'm on my way to route Broadcomm decoder to DDR3 component. I have set constraint region to make my default line width = 0.1 mm for signal wire. but in BGA there are so much power wire which need wider line width (like 0.2 mm or wider). can I set my net constraint for power in my contraint region? and how?
thanks for your help
  • Mashak
    Mashak over 15 years ago
     You can set a different set of constraints in the region defined.
    Use constraint manager help supplied by cadence......
     The process is long to explain.
  • Ejlersen
    Ejlersen over 15 years ago
    Hi
    You can put nets in a net class (select nets and right click, create, net class)
    Now you can create a region-class relation between your region and the newly created netclass. Now set the width of the region-class object and you should be set to go.
    Best regards
    Ole
