  3. PSpice question
  • Subscribers 163
  • Views 15072
PSpice question
dkrzy
dkrzy over 15 years ago
I am using a model that contains 2 .subckt models in it.
.SUBCKT MAX2611 1 2 3
* 1=input 2=output 3=gnd
L6 1 57 3N
C4 57 98 0.5P
L5 98 3 0.5N
L4 2 46 3N
C3 46 12 1P
R15 12 98 20
R10 46 57 530
R11 57 98 400
R19 46 31 150
Q2 31 57 42 98 QX
R12 42 98 270
Q3 46 42 54 98 QX
Q4 46 42 54 98 QX
R18 54 98 0.8
.ENDS MAX2611
.SUBCKT QX 1 2 3 21
CP1EPI 1 2 5.598e-14
CP1P2 12 3 8.08e-14
CTRENCH 1 20 8.61e-14
RBX 2 12 5.21
RCX 1 10 5.72
RCI 10 11 0.3015
REX 13 3 0.7
RSUB 20 21 1225
QP 20 10 12 20 TXP 6 OFF
QN 11 12 13 11 TX 6
.MODEL TX NPN( IS=2.047E-17 XTI=3 EG=1.140 BF=227.706 BR=20 XTB=450M
+ VAF=29 VAR=3.500 NF=1.010 NR=1.020 NE=1.650 NC=1.560 IKF=77.028M
+ IKR=1.411M ISE=9.681E-21 ISC=1.245E-29 RB=31.362 RBM=23.521
+ IRB=12.447M CJE=66.740F MJE=490M VJE=940M FC=990M CJC=14.423F
+ MJC=470M VJC=850M TF=3.728P TR=19N XTF=1 VTF=1K ITF=37.220M PTF=5
+ KF=1.500F AF=1 )
.MODEL TXP PNP( IS=1.320E-18 CJE=14.423F MJE=470M VJE=850M CJC=17.586F
+ MJC=400M VJC=650M BF=10K BR=746.167U TF=1N FC=900M )
.ENDS QX
I want to add the 2611 part to a schematic.  When I use the model editor it sees 2 parts, 1 for each subckt.  How can I combine these 2 to make 1 part such that I can place 1 part on my schematic to wire up?  Thanks.
  • Radio Stanice
    Radio Stanice over 14 years ago
    Yes, I think you must add MAX2611.lib instead of MAX2611.olb under configuration Tab
  • Radio Stanice
