  3. script failing?
  • Subscribers 163
  • Views 13888
script failing?
pitbull107
pitbull107 over 15 years ago
 This is the script:  (after execution the rat is still visible fro net U96-CK_C)  Can you explain what is wrong here?
Start Net U96-CK_C
setwindow pcb
net schedule
pick -723.82 8046.89
prepopup -1367.2031496063 4454.72637795276
pop Insert T
pick -1367.2031496063 4454.72637795276
pick -1367.2031496063 4153.54527559055
pick -1367.2031496063 4755.90748031496
prepopup 0.00 0.00
pop Done
setwindow pcb
generaledit
net rat U96-CK_C
rats show
generaledit
pick -13300.00 0.00
pop dyn_option_select '@:@Property edit'
property edit
setwindow form.editprop1
FORM editprop1 properties Fixed_T_Tolerance
setwindow form.editprop2
FORM editprop2 fixed_t_tolerance ele_prop_value 0.0
FORM editprop2 apply
FORM editprop1 done
prepopup; pop dyn_option_select 'Selection set@:@Clear all selections'
unrats net  U96-CK_C
rats show
End Net U96-CK_C
  • oldmouldy
    oldmouldy over 15 years ago
    It looks like your design might be using 2 decimal places, some of your co-ordinates have 10 decimal places, a) You cannot set PCB Editor to a resolution of 10 decimal places, max is 4 and b) I am pretty sure that PCB Editor won't accept values that exceed the database resolution, especially from a script.
