  3. Component Browser can't display symbol
  • Subscribers 163
  • Views 1886
jack1234
jack1234 over 15 years ago
I have a weird problem that is unique to one project in HDL Design Entry.  If I select a part in the Component Browser in the part table, the symbol does not appear in the browser window and the message "No symbol found for the part."  Yet if I double click on the part table entry, the part symbol will be added to my schematic properly even though the part symbol was not displayed in the browser.  So the problem is only with the browser, not with the library or schematic.
 This problem occurs only for certain parts in the library and only occurs with one project.  Other projects have no similar problems with the component browser.  So it must have something to do with setup and configuration of this project  but I can't find anything obviously wrong.  It only affects the component browser.  In fact I can add the same part on the command line just fine.
  • djhutchi
    djhutchi over 13 years ago
    I have 1 librarian at a remote site that is seeing the same issue today, only on an inductor symbol, while the other discrete components ( cap, ferrite & res ) all work correctly...
    Does anyone know of any debugging capablity or logging to help identify the source of these types of problems?
  • djhutchi
