  3. Package creation - Allegro
  • Views 3326
ChrisL2
ChrisL2 over 14 years ago
Prepare for a very basic question:  Does anyone know of a good tutorial that tells me how to create a new footprint?  I (think I) understand how to modify the padstack, but I'm not sure where or how to enter a footprint for a part that's not in the default library.  For example, I would like to enter a TQFP-100 package footprint in PCB Editor, and I just can't figure out where to begin.  I'm using version 16.3.  I know this is a basic question - thanks for your patience!
  • redwire
    redwire over 14 years ago
     Probably a bit hidden but take a look in your install path under "doc\algrolibdev" and find the pdf file. Should be a good start.
    Very quick start, File->New then choose Package Symbol Wizard.
    Build a part -- anything.  Then go back and edit the part and play around with the menus and see what the wizard created.  Be aware these are the bare minimum items needed.
  • ChrisL2
    This is exactly what I needed.  I knew about the algrolibdev folder, but I just needed to know to go to file->new to find the package symbol editor.  It seems obvious in retrospect, but I just couldn't find it.  Thanks!
  • redwire
     I would suggest you learn each of the File->New types that are there.  You are going to need to need each type sometime in your development process. :)
