  3. Error after user prefs modified
  • Subscribers 167
  • Views 19045
Vapor Europe
Vapor Europe over 14 years ago
Hello all, I've added a directory in the user preferences windows -> config-> paths. when i have confirmed orcad pcb editor close with an Unexpected error and now I can't use the software bacause each time I run it it gives this error
Unable to find the messaging system module definitions file 'allegro_smi_modules.txt'
ERROR:Could not initialize theAllegro error messaging system
any idea??? I don't want to install again the software and configure it from 0
Thank you.
  • allegro_smi_modules.txt
  • Rik Lee
    Rik Lee over 14 years ago
    I suspect one of the files in your PCBENV directory, most likely the allegro.ini, has become corrupt. Try renaming your PCBENV, which is usually found on your C:\ drive and then restarting the tool.
    If the tool starts you can put the PCBENV file back and then rename each file inside of it to see which specific file is the cause.
    The *.geo files in the pcbenv directory are just windows and form locations. These can be deleted and they will be regenerated as will the allegro.ini if it is deleted.
  • dcschwei
    dcschwei over 11 years ago
    Old post, but just ran into the same problem. Renaming PCBENV didn't work, and uninstalling Allegroviewer and reinstalling didn't work. However, uninstalling Allegroviewer, deleting the PCBENV folder and then reinstalling Allegroviewer did work.
  • oauser
    oauser over 6 years ago
    I ran in the same problem and I'd like to share the solution which worked for me.
    After editing libraries paths preferences within PCB Designer, the program suddenly crashed.
    After some research, I found out in PCBENV Directory (look here to know how to find it) that the file named 'env', which is supposed to contain libraries paths, was empty. On the other hand, there was another file called 'env,1' which contained the above-mentioned paths.
    Then I cancelled the empty file 'env' and renamed the file 'env,1' into 'env'. That's it, everything worked fine after.
  • srooney
    srooney over 6 years ago
    I found that I had to edit my env file in the pcbenv directory and add as the first line: source $TELENV
    For some reason my env file got corrupted and this line was missing.
    Adding that in cleared the error message the next time I launched the tool, allegro came up
  • sivavayu
    sivavayu over 5 years ago in reply to srooney
    This helped. For some reason my env file first line changed to srcsource $TELENV instead of source $TELENV.
