  3. netlist error orcad 16.2
  • Subscribers 166
  • Views 13574
Cad Engineer
Cad Engineer over 14 years ago
Dear all, lm358 part i have taken from library, i have not did any changes in that part,this part having 2 section But when i creating netlist, #10 Error [ALG0013] Conflicting values of following Component Definition properties found on different sections of U3. VALUE #11 Error [ALG0014] Conflicting values of part name found on different sections of "U3". Conflicting values: LM358_12_SOIC8_LM358_9 & LM358_13_SOIC8_LM358_10 Property values of "Device","PCB FootPrint", "Class" and "Value" should be identical on all sections of the part. In that part edit properties not showing device , class. how to found this device, class properties Regards, praveen.
  • redwire
    redwire over 14 years ago
     You've edited one segment of the part and failed to update all other sections.  You need to clean up the library (Replace cache).
    When you examine your cache you will see all of the different instances of the same part.
  • abounabil
    abounabil over 10 years ago
    Could you please guide me how to clean up the library or replace cache) ?
    same issue faced and dunno how to solve it
