  3. Passing part number from Capture to PCB Editor
  • Replies 11
  • Subscribers 166
  • Views 20043
hobbss
hobbss over 14 years ago
I am having difficulty passing part numbers from capture to pcb editor.
Every part in my design has a part number associated with it (installed from a CIS database).
My allegro.cfg file has PART_NUMBER=YES in it at the top.  However, the footprint/refdes combos in PCB Editor do not have any part number associated with the.  This is a problem when I go to create my pick and place file.  Is there some setting that I am missing?
I have attempted to go to  Setup --> Property Definition to enter PART_NUMBER, but got an error message stating that that was a reserved property.
  • bulldog
    bulldog over 14 years ago
    Hi
    We also have CIS and the problem you're having is that you need to check the Create User Defined Properites box when you import the netlist into Allegro.  In addition, Allegro.cfg must have the line PART_NUMBER=YES.  That tells CIS to put the part number in the netlist and tells Allegro to import it and put it on the components.  Try it.
  • redwire
    redwire over 14 years ago
     Are you looking at COMPONENT properties or SYMBOL properties?  The first carries the imported properties.
  • hobbss
     I have verified that the box is checked.  I then manually reimport the netlist (rather than doing it automatically from Capture).  The components still do not have part numbers.  If I look at the COMPONENT properties (not SYMBOL properties), I get the following:
     LISTING: 1 element(s)
                 < SYMBOL >
      RefDes:       Q1
      Symbol name:  TO18
      origin-xy:    (1600.00 3475.00)
      rotation:     0.000  degrees
      not_mirrored
      Attached text:
       class      = MANUFACTURING
       subclass   = AUTOSILK_TOP
       value      = Q1
      Attached text:
       class      = REF DES
       subclass   = ASSEMBLY_TOP
       value      = Q1
      Attached text:
       class      = REF DES
       subclass   = SILKSCREEN_TOP
       value      = Q1
      -------Component Instance Q1-------
      Component Class:      IC
      Device Type:          NPN_TRANSISTOR_TO18_260_2N222
        Value:              2N222
      Function(s):
        Designator: F85
        Pin(s):     1, 2, 3
      Properties attached to component definition
        PACKAGE_HEIGHT_MAX  = 260 MIL
        VALUE             = 2N222
    It seems like both the PACKAGE_HEIGHT_MAX and the VALUE properties are being transferred, but not the part number.  This is true whether or not the box for  "Create user-defined properties" is checked.  As a sanity check that the components do not have part numbers associated with them, I created a custom report (to generate a pick and place file) that should have the part numbers.  However, that field in the report is blank.
  • bulldog
    Check the symbol properties with Show Element.  Simply hovering the cursor over the part will not show the part number.  Below is a sample of one of ours:
                 < SYMBOL >
      RefDes:       U8
      Symbol name:  SKY_12
      origin-xy:    (1.5655 1.8069)
      rotation:     90.000  degrees
      not_mirrored
      Attached text:
       value      = U8
      Attached text:
       class      = REF DES
       value      = U8
      Attached text:
       class      = REF DES
       value      = U8
      Attached text:
       class      = USER PART NUMBER
       value      = 003-0831-12
      -------Component Instance U8-------
      Component Class:      IC
      Device Type:          FRONT_END_MODULE_SKY_12_SMD_0.0
        Value:              SKY65342
      Function(s):
  • hobbss
     The text in my post above is the result of executing the Show Element command on a component.
    It looks like you have the part number as attached text on the assembly layer.  I do not have that built into my component.  I do not want the part number to show up on assembly drawings (or silk screen).  I just want it associated iwth components for reporting purposes.  Is it possible that the property isn't being transferred because the corresponding footprint doesn't  have a generic Part_Number associated with it?
