  3. Passing part number from Capture to PCB Editor
  • Replies 11
  • Subscribers 166
  • Views 20042
hobbss
hobbss over 14 years ago
I am having difficulty passing part numbers from capture to pcb editor.
Every part in my design has a part number associated with it (installed from a CIS database).
My allegro.cfg file has PART_NUMBER=YES in it at the top.  However, the footprint/refdes combos in PCB Editor do not have any part number associated with the.  This is a problem when I go to create my pick and place file.  Is there some setting that I am missing?
I have attempted to go to  Setup --> Property Definition to enter PART_NUMBER, but got an error message stating that that was a reserved property.
  • hobbss
     After much banging of my head against the wall, I figured it out...
     For whatever reason, CIS was not properly mapping part number property to PART_NUMBER (even though the configuration file is set up to do so).  To work around this, I added the line
     Part Number=PART_NUMBER
    to allegro.cfg, AND left the line
    PART_NUMBER=YES
     It is important to have both lines.  Before, when I added the first line, I removed the second (YES) line -- which did not work.  I'm not sure if the order of the lines in the config file matters, but I have them arranged so that the Part Number=PART_NUMBER line is first.
    It is not necessary for footprints to have a Part Number label (unless you want it to be visible on the board) for this to work.
