  3. Creating .PDF using Tcl/Tk Utilities in Capture 16.3
  • Replies 22
  • Subscribers 171
  • Views 16980
Goblin60
Goblin60 over 14 years ago
 All,
Here's somthing a little different. I'd like to export a .pdf using the application found in  Accesories--->Cadence Tcl/Tk utilites. This gizmo (when working) produces a searchable pdf which allows one to click on components within the pdf and see properties. I've seen this work in older versions of software. Here's the hitch; I need the postscript driver path for the .pdf editor Bluebeam. I can also use the postscript friver path for Adobe Acrobat Distiller but I prefer to use Bluebeam. Attached is a .png that shows you what I am refering to. Any info will be appreciated.
Cheers,
Ron Scott
  • baimage
    baimage over 11 years ago
    Nana111 said:
     Hi there
    I have tried to create PDF files using this code:
    /// <summary>
    /// create an empty PDFDocument
    /// </summary>
    /// <param name="pageCount"></param>
    /// <returns></returns>
    public PDFDocument Create PDF Document(int pageCount)
    return new PDFDocument(pageCount);
    But it can now work.What's wrong with my code?Thanks for any suggestion .
    where is your sample project? and do you have the right pdf dll for this sample codes. and if it is compatible with this utility.
  • nandikkara
    nandikkara over 8 years ago
    Hi oldmouldy
    Can you tell me the command need to run capPdfUtil.tcl. This tcl script can be used to get the pdf of a  scheme without any additional requirements right? ( sorry i didnt understand the above comments thats y)
    Thanks in advance.
