  3. how to set design origin (0,0)
  • Views 9127
Cad Engineer
Cad Engineer over 14 years ago
Dear all, I am working with orcad 16.2 , i want to know how to set my design origin (0,0).
  • steve
    steve over 14 years ago
    Under Setup - Design Parameters - Design Tab. The Extents specify the extents of the drawing. You can use the Move origin to change the co-ordinate of 0,0. For example type 2000 2000 in the move origin and the extents will change the origin to -2000 -2000 hence 0,0 would be offset by this distance.
    If you can get the latest version of the software (16.3) then there is a much easier command under Setup - Change Drawing Origin which lets you pick the origin with a mouse pick or RMB - snap pick to.
