  3. how to place component
  • Views 13165
Cad Engineer
Cad Engineer over 14 years ago
Dear all, I am working with orcad 16.2, now i want to place component in (200,200). any easy way is there to keep component in that place directly. Thanks and Regards, Praveen kumar.n
  • steve
    steve over 14 years ago
    Hi If you need to place a component at a specific location use the command line and type x co-ord y co-ord for example x 200 200. You can also use this for drawing rectangles, lines circles etc. You could also use the ix or iy function for incremental co-ords, i.e if you are drawing a line from 0,0 then type x 0 0 then ix 100 would add a horizontal line 100 long, if you typed iy 100 then you would get a vertical line 100.
  • Cad Engineer
     Dear steve ,
     Thanks for your reply, I traid this but its giving off set error because i am not able to pick centre of  the component.
    i want to know how to pick centre of the component
    Praveen
