  3. help for dsn data to brd data
  • Views 15976
purikku22
purikku22 over 14 years ago
 hello all! i have a data converted from other cad software. i have the *.dsn and . ses files. I can open the data in the specctra but how can i convert the *.dsn file to *.brd? I need to aaif of the the data  for simulation purposes. (We have converter from .brd to aaif though).
thanks in advance!"
regards eric
  • Cadpro2K
    Cadpro2K over 14 years ago
     You can not convert the Specctra .dsn file to an allegro .brd file unless you have the .brd file you generated the .dsn file from. Good luck.
  • purikku22
     it seems that there is no way to convert a .dsn file into .brd file?
  • uamcap27
    uamcap27 over 14 years ago
    Hi s' eric,
    You can use the PCB Router Translator (a.k.a SPECCTRA Interface).
    -translate and export data from an allegro .brd, .mcm, or .sip file to an allegro PCB Router design (.dsn) file
    -translate and import data from an allegro PCB router session (.ses) file to .brd, .mcm, or.sip file in allegro
    session file contains info. regarding any placement or routing changes made to the design during the the allegro PCB router session. The session file is all that is needed to read place and route data back into allegro.
    (From cadence documentation).
    Mau
  • purikku22
     thanks for the reply.
    all i have right now is the .ses file and .dsn file.
    i dont have library and netlist. does this files necessary for importing the ses file into brd?
    when i import the .ses file to a new brd data (empty data), nothing happens...
    any help?
