  3. edit signal names in HDL following a group copy
  • Views 15923
K2J4
K2J4 over 14 years ago
How can I edit one digit of a group of signal names after I copy a schematic group without having to change these individually?  It has been some time but I recall using a text editor to do this quickly. I tried the "copy all" which did copy the signal names. Great!  But then the Tools>Global Update>Global Property Change... did not work as I expected.  I tried using a wild card (*) to retain most of the net name but the tool replaced the net name with the wild card.
  • Jerry GenPart
    Jerry GenPart over 14 years ago
    While you'll need to do this page-by-page, try this:
    Use the group command to include the signals you want to change. In the console window, type change A (where A is the group letter). The enter CTRL-E. A text editor should appear and you can find/replace the needed characters.
    Jerry Grzenia
  • K2J4
    Thanks Jerry.  This worked great.
    It also worked nicely for changing the reference designators  i.e. "2_U1" to "3_U1".
  • Khurana
    Khurana over 14 years ago
    KJ, have you tried PASTE SPECIAL command?  It does allow for modifying the signal names before pasting circuitry that's been copied using Edit > Copy.
  • Mike Veal
    Mike Veal over 14 years ago
     K2J4,
    Looking at your example I'm going to guess what you want to do and propose an alternative.
    There is another way. Is your copied section large enough to consider using a hierachical design? If so, try this:
    Create a hierachical block containing your section to be copied.
    Instantiate your block multiple times in the schematic.
    Attach the property SUBDESIGN_SUFFIX=BERT to the first hierachical block.
    Attach the property SUBDESIGN_SUFFIX=FRED to the second hierachical block.
    When you compile the design, a resistor that shows as R1 when you drill into the HB (occurance edit mode switched off) will appear as R1_BERT in the first HB and as R1_FRED in the  second HB.
    Does that help?
