  3. mentor netlist problems at upgrade orcad 10.5 to 16.3
  • Views 13336
alon123
alon123 over 14 years ago
hi,
recently I upgrade my orcad from version 10.5 to 16.3.
I load my schematic that I draw in version 10.5 in version 16.3.
The problem is when I create Mentor netlist I get something like this:
net name at 10.5 version: N27490403
when I create netlist at 16.3 version I get: N27490403_digital , when digital is name of hierarchy that N27490403 in there.
It's happen in many nets.
How can I fix this problem?
  • paragc
    paragc over 14 years ago
    Make sure you install the latest 16.3 ISR and once done you will find an option under menu "Accessories"->"Cadence Tcl/Tk Utilities"->Extended Preferences" - (See options under "Net Naming Options"). You will need to restart Capture Schematic after changing this.
  • alon123
    where can I found installation of ISR? I cant find any data about this... its not on my installation disk!
