  3. How to create drill location report
  • Views 14085
rinj
rinj over 14 years ago
 Hi all,
Can anybody help me,
How to create drill location report from a .brd file (Tool: Allegro PCB design 16.3)?
Below is an example from an orcad layout plus file.
COMMENTS   DRILL    TOOL     XCOORD       YCOORD
Holes (Padstacks with no pads defined)
            2.60 mm   1         -11.20 mm    -32.39 mm
            2.60 mm   1         -11.20 mm    32.39 mm
            2.60 mm   1          11.20 mm     -32.39 mm
            2.60 mm   1          11.20 mm     32.39 mm
rinj
  • Anaxroche
    Anaxroche over 14 years ago
     hi,
    you should create a database file for reporting tool.Tools>>Report and next choose New/Edit button.Select "Logical_Pin" caption from the "Select Database View".There is a list below now for adding data to your report list.you can choose necessary "drill_hole" definitions from the list.Save the file.When you report , you can get the file by using "Browse" button on the reports tool.
    Sample report file :
    # This is an extract command file
    # generated by the Extract UI.
    LOGICAL_PIN
    DRILL_HOLE_NAME
    DRILL_HOLE_PLATING
    DRILL_HOLE_X
    DRILL_HOLE_Y
    BOARD_UNITS
    END
