  3. .ibs file in Allegro PSB SI
  • Views 16062
Neha Anu
Neha Anu over 14 years ago
Hi all..
I have a doubt in the addition of .ibs file.
Can anyone explain how can a .ibs file be added in the dml library in the Allegro PCB SI.?
  • Neha Anu
    Hi all,
    How a .ibs file from the vendor's site be viewed in allegro?Is there any tool to check the .ibs file in allegro?
    Regards
    Neha.
  • Dennis Nagle
    Dennis Nagle over 14 years ago
    There are multiple ways to do this. If you want to view / edit / translate the .ibs file prior to use in PCB SI, I would suggest Model Integrity. There is a batch translation utility ibis2signoise. Also, if you're using 16.3, there is a flow where you can access and manage the .ibis file directly through the Model Browser in either PCB SI or SigXplorer.
  • Neha Anu
    Thank you for the information.
    I've some more doubts about this topic.
    Is there any specific path to save the .ibs file/dml file?Is it the same path that the .brd file exists?
    Thanks in advance,
  • Dennis Nagle
    When operating in the tool suite, new models are saved in your working library. By default, this is named "devices.dml" and located in the current directory.
  • Neha Anu
    Hi Dennis,
    Thankyou for your kind information.
    I need to clarify some more doubts related to the addition of the local library.
    1. Is it really needed to add a local .ndx file in the working folder other than the cadence default library?
    2. How to add the files in the default .ndx file to the locally created .ndx files/.dml files along with the models in the local .dml file?
