  3. Routing strategies for WLCSP49 package
  • Subscribers 163
  • Views 15191
mpkingsley
mpkingsley over 15 years ago
Looking for routing guide lines or constraints of Pad size, trace width and copper thickness.
  • Cadpro2K
    Cadpro2K over 15 years ago
     Cool. Where the future is headed. Next up .3mm pitch
     Will need some form of HDI/ALIVH routing technique, dependant on how many GND pins you have.
    Pads should be .25mm - with .12 laser vias in the pads
    GND pads should go directly to a 2nd layer GND plane
    Best case is going 2 structures of micro vias; stacked over each other to break this out, minimum. Pretty common for fabricators - but expensive compared to traditional fabrication.
    Line width will probably need to be .1mm or less, sorry.
    You'll still have some routing challenges, but you'll see. There are also a number of internet articles for routing these packages.
  • Cadpro2K
