  3. No Brd output to layout.
  • Replies 16
  • Views 18747
IanByrne
IanByrne over 14 years ago
 So, I follow the steps to create my design (schematic) I get it done, no errors and then save the file.
I try to "Export Physical" to have it able to go into the layout but there seems to be an eternity before it pops up and then it does not create the brd file. When I open the PCB Editorto try open the file it is nwhere to be found!
Am I missing a step? I have tried the tutorials/manuals but to no use asd there is no other step I seem to be missing.
Any help, much appreciated.
  • redwire
    redwire over 14 years ago
    scottiem said:
     You have to have .brd made up already. Once you have exported the physical from the schematic editor, you have to open a.brd file then import the physical. You will also need to have your footprints made up for the component. Otherwise you will not be able to import the schematic.
    This is not true.  You can start with a blank file. If you use OrCAD or Concept it will generate a BRD file without an existing file.
    Your comments indicate that you are only familiar with the import logic flow.
    Back to the OP.  You need to make sure there are no DRC errors or warnings that are tripping up the packager.  Something is preventing it from completing.  Review the session log file.
    Or if needed, post up the packager files...
  • Cadpro2K
    Cadpro2K over 14 years ago
    1) create a "dummy" board in allegro. at least put an outline in and save it (.brd).
    2)  since you have already exported physical, you've created the required files in a folder called PACKAGED
    3) open the .brd file; FILE/IMPORT LOGIC
      - in the import logic GUI, lower right,  browse and select the appropriate PACKAGED folder
      - import logic
    if there are no errors, you should be able to start placing your parts (footprints). PLACE COMPONENTS/manual
    GO FOR IT.
  • scottiem
    scottiem over 14 years ago
     Hi Redwire,
     You are correct i didn't realise you could start without a .brd but don't you need a mech (ie board outline, package keepin as a minimum
  • IanByrne
     SO I packaged the file, or so I think....when I go to the layout and import the logic, this is the resulting info I am given! (netrev.lst file)
    ANy help appreciated! (I used XXXX for this online thread)
    ------ Directives ------
    RIPUP_ETCH FALSE;
    RIPUP_SYMBOLS ALWAYS;
    Missing symbol has error FALSE;
    SCHEMATIC_DIRECTORY 'H:/Cadence/XXXX Board Project/worklib/design_ce_eu_power_board';
    BOARD_DIRECTORY '';
    OLD_BOARD_NAME 'H:/Cadence/XXXX Board Project/worklib/design_ce_eu_power_board/physical/design_ce_eu_power_board.brd';
    NEW_BOARD_NAME 'H:/Cadence/XXXX Board Project/worklib/design_ce_eu_power_board/physical/design_ce_eu_power_board.brd';
    CmdLine: netrev -$ -i H:/Cadence/EU Power Board Project/worklib/design_ce_eu_power_board -l -u -y 1 -o H:/Cadence/EU Power Board Project/worklib/design_ce_eu_power_board/physical/#Taaaaaa04084.tmp
    ------ Preparing to read pst files ------
    #1   ERROR(24) File not found
         Packager files not found
    #2   ERROR(102) Run stopped because errors were detected
    netrev run on Mar 14 7:10:12 2011
       COMPILE 'logic'
       CHECK_PIN_NAMES OFF
       CROSS_REFERENCE OFF
       FEEDBACK OFF
       INCREMENTAL OFF
       INTERFACE_TYPE PHYSICAL
       MAX_ERRORS 500
       MERGE_MINIMUM 5
       NET_NAME_CHARS '#%&()*+-./:=>?@[^_`|'
       NET_NAME_LENGTH 24
       OVERSIGHTS ON
       REPLACE_CHECK OFF
       SINGLE_NODE_NETS ON
       SPLIT_MINIMUM 0
       SUPPRESS   20
       WARNINGS ON
      2 errors detected
     No oversight detected
     No warning detected
    cpu time      0:03:04
    elapsed time  0:00:00
  • IanByrne
     Do I have to name eachNET? As it stans the NETS are of types like this:
    Signal: UN$1$CAPNP$I17$B selected.
    Should I name them as, "NET_1" etc......?
