  3. how to draw mechanical symbols
  • Views 15481
graceliu1973
graceliu1973 over 14 years ago
I do not know how to draw a mechanical symbol in allegro pcb design.for example a circle hole or a square hole for assemble.
  • steve
    steve over 14 years ago
    In Allegro use File - New - Mechanical Symbol, draw the item you want, add pins (mechanical ones only) etc. Save the file ensuring it is in your psmpath directory. Then in the actual board file use Place - Manually, check the adavnced settings tab to make sure your library is checked, the back on the placement list tab change the Components by refdes to Mechanical Symbols, your new symbol should be in the list. Place it from there.
