  3. Packaging Error
  • Replies 8
  • Subscribers 166
  • Views 24252
Packaging Error
IanByrne
IanByrne over 14 years ago
When I try to package my schematic design for layout, I get errors, not able to create file.
I have a .brd file created already but can't import the logic.
Help?
  • steve
    steve over 14 years ago
    Can you add more detail ? What schematic software ? What errors ?
  • IanByrne
     I am using Allegro PCB Design HDL andhave a very simple circuit. I have no schematic errors but when I try to package it for the layout, it hangs and gives me errors.
  • andri26
    andri26 over 14 years ago
     can you post log data from export physical process?
    we can see what the problem is from there..
  • IanByrne
     Can't find that. It gives me no log file to view! (It takes forever it seems to even get this far!)
    But when  I try to import logic file I get this:
    Cadence Design Systems, Inc. netrev 16.2 Tue Mar 15 08:36:26 2011
    (C) Copyright 2002 Cadence Design Systems, Inc.
    ------ Directives ------
    RIPUP_ETCH FALSE;
    RIPUP_SYMBOLS ALWAYS;
    Missing symbol has error FALSE;
    SCHEMATIC_DIRECTORY 'H:/Cadence/EU_Power_Board_Project/worklib';
    BOARD_DIRECTORY '';
    OLD_BOARD_NAME 'H:/Cadence/EU_Power_Board_Project/worklib/design_ce_eu_power_board/physical/design_ce_eu_power_board.brd';
    NEW_BOARD_NAME 'H:/Cadence/EU_Power_Board_Project/worklib/design_ce_eu_power_board/physical/design_ce_eu_power_board.brd';
    CmdLine: netrev -$ -i H:/Cadence/EU_Power_Board_Project/worklib -l -u -y 1 -o H:/Cadence/EU_Power_Board_Project/worklib/design_ce_eu_power_board/physical/#Taaaaaa02704.tmp
    ------ Preparing to read pst files ------
    #1   ERROR(24) File not found
         Packager files not found
    #2   ERROR(102) Run stopped because errors were detected
    netrev run on Mar 15 8:36:26 2011
       COMPILE 'logic'
       CHECK_PIN_NAMES OFF
       CROSS_REFERENCE OFF
       FEEDBACK OFF
       INCREMENTAL OFF
       INTERFACE_TYPE PHYSICAL
       MAX_ERRORS 500
       MERGE_MINIMUM 5
       NET_NAME_CHARS '#%&()*+-./:=>?@[^_`|'
       NET_NAME_LENGTH 24
       OVERSIGHTS ON
       REPLACE_CHECK OFF
       SINGLE_NODE_NETS ON
       SPLIT_MINIMUM 0
       SUPPRESS   20
       WARNINGS ON
      2 errors detected
     No oversight detected
     No warning detected
    cpu time      0:02:37
    elapsed time  0:00:00
  • steve
    When you package the design using File -Export - Physical for now uncheck Update PCB Editor Board. Then click on OK. Does the packager complete sucessfully ? If so open PCB Editor and use File - Import - Logic, Select HDL as the input type and browse to where the packager files are (it uses three and if you use the default naming conventions will be H:/Cadence/EU_Power_Board_Project/worklib/folder name/packaged (where folder name is the Design name). Once set PCB Editor should find your packaged files and continue with the import. That is the current error shown above.
