  3. viewing Layout gerber in Allegro
  • Views 24167
sharted
sharted over 14 years ago
I have some Gerber files (generated by Orcad Layout) that I want to view with Allegro PCB Editor (V16), but I am having trouble importing them.
I am using File>import>artwork, then selecting my files.  once I do this, it gives me errors because I don't have a art_param.txt file in the directory or a art_aper.txt.  I tried to work-around by generating gerber files from an existing project in 4x00 format and hit AUTO in aperature settings.  this created the two missing files.  I copy-pasted these files into the directory with the Orcad Layout and then tried to import, but I think my aperatures are way off.  all of the lines on the imported gerber files end up way too large.  here is a picture of what I get after I do this process:
failed gerber import
as you can see, all of the lines are way too fat.  however, the text near the top-right seems good.  what do I need to fix in order to view these files in Allegro?
 would it help if I posed my art_param and art_aperature files?
  • steve
    steve over 14 years ago
    Allegro / Orcad PCB Editor are great at viewing artworks created by Allegro / Orcad PCB Editor. For other gerber data generated by different tools you can do it but there is lots of work to do with apertures etc to make it work and it's not worth the effort. If you just want to view gerber files then get something like GC-Prevue or viewmate from the web (free version's available). Much easier.....
