  3. How do you uninstall ISR?
  • Subscribers 166
  • Views 14321
Padmaster1
Padmaster1 over 14 years ago
I installed 16.3 so26 ISR this morning and now Orcad CIS will not open. The splash screen comes up and I can see the program in the task bar but it will not expand.
Now how the heck do you uninstall an ISR? I know I've done it before......3-4 years ago.
  • redwire
    redwire over 14 years ago
     ISRs uninstall like any program uninstalls.  Use the control panel, add remove programs.
  • andri26
    andri26 over 14 years ago
     usually you just need to uninstall this software via 'add&remove program' but i also delete its registry with registry editor
  • Padmaster1
    hmmmm, well I don't see any of the ISR's listed in the add/remove Programs dialog box.
  • redwire
     Did you install it in a separate path from the regular release?  It should show up as whatever base version of software you're running.
  • andri26
    you can manually delete cadence folder in your computer :)
    but its  alittle bit  rascal, lol
