  3. REG:DLIB command
  • Views 470
REG:DLIB command
girish
girish over 14 years ago
When I use DLIB command to extract padstack files related to the  particular footprint ,
it will dump  so many other pad- stacks ( previously used pads in that file but currently not being used) along with the  actual padstacks used in the footprint.
How to dump only the pad-stack used currently &avoid all previously used padstack in that file ?
One more thing while dumping if the same padstack already available in that path , it will not give warning .
Please clarify me
Girish Kumar
  • mcatramb91
    mcatramb91 over 14 years ago
    Open up the footprint symbol and purge the padstacks that are not used in the symbol.
    Tools > Padstack > Modify Design Padstack.. and under the options tab you will find a Purge Button that will give you the option to purge all unused padstacks in the symbol then save the symbol.
    As far as your overwrite issue without a warning, I would suggest setting env variable ADS_BOARDREVS to 2 so if a padstack is exists it will be moved to a <padstack name.pad>,1   This setting is available via the Preference Editor under the File Management category.
    Hope this helps,
    Mike Catrambone
    Plexus Engineering Solutions
  • girish
    Thanks Mike for spending your valuable time !
    It really helps to me
    Girish kumar
