  3. Capture Group Replace Symbols
  • Views 15354
themaccabee
themaccabee over 14 years ago
I ve  been using Capture from Cadence 16.2.
Ive got a schematic page.Ive got a lot of Ground Symbols in it.
I want to change the ground symbol to another symbol that is default available in Capture say GND-EARTH to GND or GND-FIELD SIGNAL.
I dont want to delete each one maually and connect a new one..
Is there a solution?
Thanks For Any help
Regards
Stephen
  • KEN13
    KEN13 over 14 years ago
       If you want to change it globally select the gnd symbol in your cache and use the replace cache command.  If it is on a single schematic page among a multiple page schematic...save a copy of the schematic use the replace cache command and then move the updated page into your original schematic.
    Have a good weekend.
  • themaccabee
     Thank You Ken it worked..But the connection seems to be lost while doing this..
