  3. Component Information System Basics
  • Views 13277
themaccabee
themaccabee over 14 years ago
Im a beginner in Cadence.Previously using Altium Designer..I had to change because my team changed..
I believe there is a component information system in Capture..Im using Cadence 16.2
What i would like to do is integrate digikey component parameters into the schematic component properties..so that when generating BOM all these information is converted to a excel sheet.
I altium there had been a brief setup procedure after which you could hit the Digikey part number in a search box inside schematics that will display digikey part nos then i needed only just to select the digikey part and click on schematic component i like ...
May be there exists some similar way in capture..?? For the Component information feature to be availble  in Cadence 16.2
1.Shall we need to purchase anything extra ?
2.Is there any good tutorial for a beginner to setup this CIS.
Thanks & Regards
  • redwire
    redwire over 14 years ago
     Yes, this capability exists..however a couple of lines in a forum reply are hardly enough to help.
    They used to offer the full DigiKey library for CIS...what the state of affairs is today, I don't know.
    Look here: http://www.cadence.com/products/orcad/pages/downloads.aspx#starter
    The CIS User guide in its current incarnation is in your doc\cisug directory where you installed OrCAD.
    Search the internet for DigiKey starter database....
