  3. [Solved] Allegro PCB Editor 16.3: Modifying Shapes
  • Views 23562
ScottG
ScottG over 14 years ago
Hello, Does anyone know if there is a way to modify the coordinates of an already placed shape in Allegro? For example, changing the coordinates that define a rectangle. The most I've been able to find is right clicking the selected shape and clicking "Show Element". This brings up a text box with the exterior boundary that defines the rectangle's dimensions. But you can't change the values... I am working on drawing footprints. It seems terribly inefficient to have to type in the coordinates to draw a new rectangle and delete the old one, especially if you just accidentally type one coordinate incorrectly... Any help would be appreciated. Thanks
  • Randy R
    Randy R over 14 years ago
    Shape->Select Shape or Void then click on the shape to edit.  Small boxes will appear at each vertex of the shape.  Click on the vertex you want to change.  You can drag it or type in absolute or incremental coordinates.
  • EvanShultz
    EvanShultz over 14 years ago
    I often use Shape > Edit Boundary because it allows both expanding and contracting a shape within the same tool. It also uses polygon selection so I find it to be quicker than Select Shape in many cases.
