  3. How to mask-out all but a highlighted net, component, pin...
  • Subscribers 163
  • Views 16363
How to mask-out all but a highlighted net, component, pin, etc?
kidder03
kidder03 over 15 years ago
Is there way to darken the entire PCB design, such that the selected net is noticeably brighter, and higher in contrast than the rest of the design?  I have used other design tools which use a "mask level" feature to keep the selected net, component, pin etc. at a given highlighted brightness, and darken out the rest of the design to make the selected item stand out VERY well.  Thank you.
-adam
  • Mstrghettorigg
    Mstrghettorigg over 15 years ago
    If you are using Allegro then you can just use the "Shadow Toggle" button after you highlight the nets that you like to see. Hope this helps.
  • kidder03
    That was it.  Thanks for the prompt answer to my very rookie question!
